Furzul
Message 1 of 7
BT Mobile app
I have noticed that when I check my usage in the BT Mobile app, if I scroll down to where it says wi-fi calling and 4G calling it now says no to both. Not a big problem because ithey both still work. Just wondered if anybody else sees the same.
6 REPLIES 6
Dean007
Recognised Expert
Message 2 of 7
Re: BT Mobile app
Hi @Furzul
I wouldn’t worry about that. It is used to show if your SIM is in an officially supported device. So more of a visual than anything else.  😀
Furzul
Message 3 of 7
Re: BT Mobile app
Not worried. It is just that it used to say yes to both. Like I say wi-fi and 4G calling still work. Maybe because the sim is in the new iPhones Xs
Dean007
Recognised Expert
Message 4 of 7
Re: BT Mobile app
@Furzul
It doesn’t show for my Max either! I’ll send a message see if someone can update it
Are you happy with your new phone? 📱
Furzul
Message 5 of 7
Re: BT Mobile app
Yes, very happy. I had the X last year but the wife wanted that.
Dean007
Recognised Expert
Message 6 of 7
Re: BT Mobile app
@Furzul
A good excuse to buy a new phone. 😀
Furzul
Message 7 of 7
Re: BT Mobile app
Yes, I thought so.
