Message 1 of 4
BT Mobile can you order 2 sims on the same order?
After logging onto MyBT there is an offer popping up with an offer for BT Mobile . I started to fill this in and as myself and my wife have a EE sim I expected to be able to order one for her.
Do we have set up  separate orders with separate accts. as a the moment it is billed as one.
thanks
Mike
3 REPLIES 3
Message 2 of 4
Re: BT Mobile can you order 2 sims on the same order?
Hi @thewheelshavecomeoff
After placing your order, does it give you the option to place another order on the same account?
Ali
Message 3 of 4
Not got that far did not want to create one and then my wife had to add another. the offer is very vague with no details on what to do if you have more than 1 phone
Mike
Message 4 of 4
Hi @thewheelshavecomeoff.
If the offer does not allow you complete for both SIMs, I would recommend giving us a call and speaking with the team who can advise if the offer can be used for both numbers rather than one.
Katie
