gomezz
Recognised Expert
Message 11 of 16
Re: BT Mobile now allow Tethering
@RobbieMac wrote:
Hi guys,
I asked the question about tethering on Windows phones and the good news is that this will also be supported Smiley Happy
Cheers,
Robbie
Thanks for that.  Means I can put BT back on the list as I look to change from a 3G to a 4G contract (currently on O2 so not possible to check for myself).
Keeping-up
Message 12 of 16
Why do all their adverts still say that tethering is not allowed?
Message 13 of 16
I have not seen any advert that said there was no tethering as it was always in the T&C  It has been removed from new T&C but iphone is waiting for update to remove the block on tethering whereas you could always do with android
Message 14 of 16
Good news; Following the latest carrier update from BT tethering is now available on iPhones.
odonovs
Message 15 of 16
'carrier update'
I can tether with my LG G3 (Android) but not my wife's iPhone 5. On the latter the hotspot screen is not enabled. What did you mean by 'carrier update'?
thanks
Sean
odonovs
Message 16 of 16
Ah - updated to ios 9.3.2 and hey presto Personal Hotspot became available under mobile network setting!
