Message 1 of 16
BT Mobile now allow Tethering
BT Mobile announce that they now allow tethering on android devices and soon to be enabled for Iphone (IOS devices)
Distinguished Guru
Message 2 of 16
Re: BT Mobile now allow Tethering
hi. Thanks have you a link/source?
thanks
dd
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 3 of 16
Distinguished Guru
Message 4 of 16
There's no mentioning of any prohibition of tethering in the new T&Cs coming in on the 3rd July http://www.productsandservices.bt.com/products/static/terms/post3rdjuly2016mobile-service.html but there was on the old ones http://www.productsandservices.bt.com/products/static/terms/mobile-service.html
orozz
Message 5 of 16
gomezz
Recognised Expert
Message 6 of 16
What about Windows phones?
Message 7 of 16
@gomezz
try and see.  even though tethering was not permitted before you could still tether using android but not iphone as it was blocked - so have you an option to tether in your windows phone?  if so try it
Moderator
Moderator
Message 8 of 16
Hi guys,
I asked the question about tethering on Windows phones and the good news is that this will also be supported Smiley Happy
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
orozz
Message 9 of 16
Is tethering available both handset and sim only contracts?
Guru
Message 10 of 16
Stew
