NC3
Message 1 of 3
BT Mobile
BT Mobile once’s worked but now after repeatedly reloading the BT Mobile App without succcess, BT informed me to send data logs twice. That was a month ago and nothing heard back? Premium price for a poor service. Can anyone help?
Moderator
Moderator
Message 2 of 3
Re: BT Mobile
Hi @NC3 sorry you are having a problem with the App for your BT Mobile account. Please contact the Mobile Chat Helpdesk and they will be able to update you on what is happening with your fault.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
NC3
Message 3 of 3
Re: BT Mobile
Thank you, mobile chat couldn’t help directed me to mobile.apps.support@bt.com. Unfortunately these are the people that over a period of 6 weeks have not responded. How do I proceed? Not impressed
