MightyIron67
Message 11 of 19
Re: BT Plus, merging a mobile and broadband account...
@NeilO
Btw, I never rang in this morning...!!
MightyIron67
Message 12 of 19
@NeilO
Sorry forgot to add that on my number I’ve still got no access on the BT Mobile App...Ive tried resetting and reinstalling etc...
MightyIron67
Message 13 of 19
@NeilO
Ok, latest bill generated 6th July lists charges for BT Plus Broadband, Landline, BT Sport and Mobile. However doesn’t mention MY mobile, just my wifes with the BT Plus benefits included...
Also...still no access via the BT Mobile app with my number, the wife has access and it includes all benefits from BT Plus...
Frustrated...
MightyIron67
Message 14 of 19
@PaddyB
@Deano
@NeilO
Anyone, available?
Dean007
Recognised Expert
Message 15 of 19
Hi @MightyIron67
You are not having much luck are you, the mobile team are the ones that will need to fix the issue. It also looks like @NeilO maybe looking after your case. Once they have the technical issues resolved that should fix all the app and billing issues also.
I will ask the mods to have a chat, they are the only ones who can see your account. It will get sorted out, if you can just stay with it a little longer Smiley Happy
JohnC2
Moderator
Moderator
Message 16 of 19
Hi @MightyIron67 Sorry that this is not sorted yet. It is not something we can fix directly so Neil will raise it back into the Mobile team to fix this for you and they will be in touch as soon as they can.
Cheers
John
MightyIron67
Message 17 of 19
All help much appreciated...!!!
Thanks...
MightyIron67
Message 18 of 19
Update 7pm 10 July 2018
So, 4 days on from the latest input, above, my number and handset which are due for an upgrade incidentally are still not available in my “BT Plus” account...I CANT EVEN PAY THE MOBILE CONTRACT OFF AND CANCEL... after speaking with customer services.
BT Plus, seems the rollout of this package has been problematic for BT.
Waste of my time and money...
MightyIron67
Message 19 of 19
Cancelled Sucessfully...
