Message 1 of 7
BT ROAM LIKE HOME
Hi soon going to Poland and want to use mobile it says
on account included roam like home  , do I need to do anything or am I ok just to go ?
thanks
6 REPLIES 6
Message 3 of 7
Re: BT ROAM LIKE HOME
You need to go to MYBT and ensure you have you phone set to be used international.  In addition you need to ensure your spend limit for international calls is set to greater than zero otherwise will not let your phone work
Message 4 of 7
Where’s it say all that as I can’t see it
Message 5 of 7
I don't have a BT mobile but I would go to MYBT then products then mobile
Message 6 of 7
@Arryz I've just posted the link to the information you requested
Message 7 of 7
I found the settings for each phone , not simple as per normal always hidden , but sorted now thanks
