Daisy2911
Message 11 of 12
Re: BT Reward Card - Problems Claiming It
Thanks to you too @Dean007 🙂
Moderator
Moderator
Message 12 of 12
Hi @Daisy2911,
Thank you for posting back. I'm glad you've been able to claim your Rewards Card :smileyhappy:
Cheers
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
