Message 1 of 2
BT SIM
Is it possible to get a BT SIM for my unlocked phone before I change operators so I can test whether a. I can get a signal and b. whether wifi calling works with BT Mobile. As remarked before they won't update their two and a half year old page with up to date information.
1 REPLY 1
Expert
Message 2 of 2
Re: BT SIM
All BT Simo plans come with a 30 day money back guarantee, simply order a sim plan, don't use a PAC code and test it where you visit the most, if you like it then use a PAC code to retain your existing number, if you don't just call up and cease before the 30 days are up.
