Message 1 of 3
BT mobile plan Tiers?
https://www.bt.com/assets/pdf/BT_PhoneTariff_Residential.pdf
In that page above, on section BT Mobile Plans – 4G Handsets, what are these Tier mean?
They seem to make price different. How is it determined?
Thanks in advance!
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: BT mobile plan Tiers?
I’d hazard a guess and say that the tiers are determined by the value of the handset you select.
BT-M will want to make a profit, so would take into account the cost of the handset and the wireless subscription on a 24 month basis and add a % to that in line with market standards.
I doubt they’d officially disclose the calculation as it could be deemed as commercially sensitive but you could reverse engineer it by looking at the handsets page and working it out.
Message 3 of 3
Hmm OK. That sounds reasonable enough. Thank you very much!
