kblokey
Message 1 of 14
BT signal assist problem
I have a problem with my BT signal assist box. Since this morning it has been flashing green rapidly. I have just got off the phone to BT after speaking to someone with the name Mike ( which blatantly isn't his real name) who didn't even know what it was. He kept going on about my hub. He didn't have a clue. So hopefully this will be picked up by someone who CAN help.
The manual says rapidly flashing is initialising or a problem. I have restarted hub and booster to no avail.
Any help will be appreciated as until its sorted my BT mobile signal is useless at home. Thanks in advance
13 REPLIES 13
Andyk9
Newbie
Message 2 of 14
Re: BT signal assist problem
Following post with interest as mine is doing the same thing as of today.
Andyk9
Newbie
Message 3 of 14
Im Following post with interest as mine is doing exactly the same as of today. It was working perfectly.
Andy005
Message 4 of 14
Mine went solid red and is now flashing green after rebooting. I suspect it's some sort of authentication error at BT's end, you would hope that someone at BT is already on the case so I'll give it 24 hours or so (it'll take that long to find someone who can do something about it anyway).
ChrisB
Expert
Message 5 of 14
Mine doing the same. It was solid red. On reboot/reset it is now fast flashing green. Something's been done at the server end and they've not mentioned it!
barnpiece
Expert
Message 6 of 14
Same here. Solid red and now flashing green.
kblokey
Message 7 of 14
OK that answers that one. Its not just me. It doesn't answer the question if why didn't the BT so called customer service assistant know what the hell it was in the first place? I could hear the wheels and cogs meshing together in the silence when I mentioned it. Anyway heres hoping they get their finger out
kblokey
Message 8 of 14
Could be more widespread as there is signal assist box attached to the WiFi at my place of work and since I got here that is red also. Mobile provider her at work is EE. Broadband provider unsure. Believe is BT but no one in IT to ask.
barnpiece
Expert
Message 9 of 14
It is working again here this morning.
ChrisB
Expert
Message 10 of 14
Working this morning
