JimboAlfie
Message 1 of 5
BT smart Talk
My BT smart Talk crashed sent detail to BT. They emailed me to say problem has been fixed and to download the app again. However it still won’t work. Spoke to 3 BT staff one knew nothing about BT Smart Talk. Then was told if you remove APP it takes 21 days before you can download it again.
Can anyone confirm if this is true. Thanks
4 REPLIES 4
Dean007
Recognised Expert
Message 2 of 5
Re: BT smart Talk
Hi @JimboAlfie
I am not sure on the answer to this one, lets see if we can get a moderator to clarify...
Moderator
Moderator
Message 3 of 5
Re: BT smart Talk
Hi @JimboAlfie
Thanks for your post and welcome back!
Sorry for the problems you're having setting up Smart Talk.  You should be able to download the Smart Talk app more or less straight away, you don't have to wait 21 days to  download it again.
As you have been speaking with numerous people and you're still no further forward we will look into this for you from here to understand why you're having a hard time setting it up again.
Click on my username here >> RobbieMac << and you'll see our contact link underneath my profile picture.
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
JimboAlfie
Message 4 of 5
Re: BT smart Talk
Hi
Thanks for your message. The app worked this afternoon but crashed again tonight.
Thanks for taking the matter up
Regards
James
JimboAlfie
Message 5 of 5
Re: BT smart Talk
Hi
Recived email from you this morning but can't find it on community.
