valeriopa
Message 1 of 4
BT wifi on laptop if only BT mobile?
Hi,
I would like to get a BT mobile 2GB plan, and I have NO Broadband contract.
BT mobile 2GB plan I get unlimited BT wifi access. However I don't know if the access is from any device.. i.e. can I use BT wifi on my laptop with the same account?
Thanks!
v
Tags (2)
3 REPLIES 3
orozz
Message 2 of 4
Re: BT wifi on laptop if only BT mobile?
My BT Mobile credentials worked on my laptop with BT Wifi. Used 20GB without problems when away in Wales last year.
valeriopa
Message 3 of 4
Thanks. I am not sure it woudl work.
When I try to login on a BT wifi, it ask you to identify as one of the following:
- bt broadband customer
- bt business
- bt wifi
- FON
...etc.
but there is no option for bt mobile.
orozz
Message 4 of 4
Just used BT Wifi login screen. If using Windows 10 there is a BT wifi app you can use to auto login.
