robartist
Message 1 of 3
BT with fon wifi on mobile
Hi and good evening
Am finding it more or less impossible to connect to btwi-fi when I am away from home. I meant the free wifi you can get if you have  bt broadband at home as I do.
I start wifi on phone
I then select btwi-fi
I enter name and password
It fails!
This has happened countless times. And I've found it a problem for years on different phones and different SIM networks.  (it used to be called bt fon or something like that)
Is there any cast iron guaranteed way to login to btwi-fi??
2 REPLIES 2
imjolly
Message 2 of 3
Re: BT with fon wifi on mobile
can you connect using the BTWIFI app to your btwifi broadcast from your own hub. That will give the base for phone to connect to btwifi when out and about
robartist
Message 3 of 3
When I am at my home address I have absolutely no problem connecting to bt wifi from my home hub.
It's only when I am away from home I have these problems.
