Message 1 of 2
Bt Hotspots & mobile data
Hello
After much deliberation I have decided to get a smart phone (the BT Galaxy A12). I have a question - I understand that using the phone at home I would connect to my BT wifi and so it would cost me nothing - but if I went on holiday and connected to a local BT hotspot, does that use up some of the data allowance or would that be free as well?
Keith p
1 REPLY 1
Message 2 of 2
Re: Bt Hotspots & mobile data
Your allowance is used when connecting to the 4G or 5G network.
If you're connected to your home/friends Wi-Fi, the free hotspots or another free access, it won't use your allowance in any way, which means it won't cost you.
