Smithy99
Newbie
Message 1 of 2
Bt sim not working
Ordered bt sim only but I got no signal/ service and when I go on my iPhone 6 and click general/about/network says sim not provisioned even though I have activated sim and got the email from bt,I tried resetting phone and starting a fresh also resetted network settings and a new sim but no luck so far No faults in area either
Thanks in advance
1 REPLY
Moderator
Moderator
Message 2 of 2
Re: Bt sim not working
Hi @Smithy99,
I'm sorry your experiencing issues with your BT Mobile. Have you managed to get this sorted?
If you still need help I would suggest you contact the BT Mobile Chat Team
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
