Tarnbrick
Message 1 of 10
By mobile withheld number
Anybody know why calls from my BT mobile windows phone arrives at destination as number withheld. I have never asked for this and I have had the phone for a couple of years but only just discovered that it happens.
9 REPLIES 9
Message 2 of 10
Re: By mobile withheld number
Have you been in touch with the BT Mobile Chat team to see if they are able to help?
Also check the call settings on your phone.
Tarnbrick
Message 3 of 10
Hi Keith
Thanks for your reply. I will try that but I have never had much success with BT chat lines, they are ever so polite and patient but never actually seem to have the answer to the query.
I can get around the situation by prefixing a call with 1470 but I would rather find out why it is doing it.  Normally you have to have the number withheld feature set up by BT but I never asked for it.
John.
Message 4 of 10
If chat cannot help you, then please post back here. I assume you have checked all the setting on your phone?
Tarnbrick
Message 5 of 10
Yes. There are no settings on my phone to create or undo any withheld number facility.
Chat line unable to help. Don't seem to understand what I am trying to do.
Message 6 of 10
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
Tarnbrick
Message 7 of 10
OK. Thank you.
Carlusha
Message 8 of 10
You have a Windows mobile phone?
Show/Hide Caller ID
1. From the Start screen swipe left.
2. Scroll to and tap Phone.
3. Tap the Menu icon.
4. Tap settings.
5. Under Show my caller ID to, select the desired option from the drop-down list.
Tarnbrick
Message 9 of 10
Thank you. Problem now sorted. Never saw that part of the settings before.
Moderator
Moderator
Message 10 of 10
Great advice posted by @Carlusha. Thanks for helping out Smiley Wink.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
