Dr51
Message 1 of 20
Calls go to voicemail
HELP! Why do all my calls go straight to voicemail! Do not disturb is not on, Ive reset settings. I’ve asked bt. Nothing works. If I turn voicemail off then if someone phone my phone nothing happens.
19 REPLIES 19
JohnC2
Moderator
Moderator
Message 2 of 20
Re: Calls go to voicemail
Hi @Dr51 Sorry you are having difficulty receiving calls on and they are going straight to the voicemail service.
Please contact the Mobile Complaints Team and they will be able to help you resolve this. Post back and let us know how you get on.
cheers
John
Dr51
Message 3 of 20
I have been onto them twice, the 1st advisor acknowledged there’s a problem an resolved by changing carrier settings to bt 3G. That option he now gone. The other advisor phoned me and his call came through! 99% calls don’t!
JohnC2
Moderator
Moderator
Message 4 of 20
Hi @Dr51 Sorry that you have not been able to get this resolved. Are you sure that it was the mobile complaints chat team and not the standard one as they should be able to sort this out for you.
If it was then we will be happy to step in and lend a hand with this if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
Dr51
Message 5 of 20
I’ve just been on again. I was advised to dial 15713 then 15711. Awaiting a call to see if this has solved the problem
Dr51
Message 6 of 20
Hey after about 2 months of this I’m now receiving calls 🙂
PaddyB
Moderator
Moderator
Message 7 of 20
Hi @Dr51,
Thank you for posting back, I'm glad that has fixed the issue Smiley Happy
PaddyB
Dr51
Message 8 of 20
😡😡😡 not fixed after all! Gggrrrr
Keith_Beddoe
Message 9 of 20
@Dr51
Contact @JohnC2 as requested. I have marked this thread unsolved for you.
Dr51
Message 10 of 20
I’ve noticed this seems to only be when connected to Wi-fi??? Any ideas
