fby
Message 1 of 5
Can I change my mobile number?
Hello,
I had a landline & Fibre 1, now I added BT mobile.
Today I received my SIM card and mobile number.
I would like to change my mobile number (not used yet) – how can I do this?
Does it cost anything?
Many thanks!
Tags (1)
4 REPLIES 4
Anonymous
Not applicable
Message 2 of 5
Re: Can I change my mobile number?
If you want to keep your old number, you need a PAC code from your old provider. They are obliged by law to issue one on request. No charge
fby
Message 3 of 5
Thanks, no, I don't have an old number – I just wanted to change the number I got.
StewM
Distinguished Guru
Message 4 of 5
The number will be allocated to that SIM. You need to speak to the Mobile Team and ask for another SIM and number. (Unsure whether there is a charge).
Stew
fby
Message 5 of 5
Thank you!
