Bakey72
Newbie
Message 1 of 2
Can I delete MMS apn settings
I've just got a BT sim for my youngest daughter who never sends an MMS.  Incase she accidentally does though and incurs extra charges is it ok to delete the BT MMS apn from her settings? I wasn't sure if I did it would affect anything else but presumably the BT internet apn is for her data.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Can I delete MMS apn settings
@Bakey72 yes that will stop MMS texts from being sent and received but most phones also have the facility to turn off MMS messages in the handset settings.
If you want to ensure your daughter doesn't run up an unexpected bill it may also be worthwhile setting up a spend cap
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
