jharchpoint
Message 1 of 2
Can I transfer from a handset plan to a sim only plan
I have a handset plan with BT mobile which is now out of contract. Is it possible to change this to a sim only plan or would I need to set up a new plan and transfer the number?
1 REPLY 1
-Richie-
Guru
Message 2 of 2
Re: Can I transfer from a handset plan to a sim only plan
You can downgrade to a new Sim only plan when in the last 30 days or out of the minimum term, look at the offers at www.bt.com/mybt or calling the mobile loyalty team on 0800 800 150 or 150 from your BT Mobile.
