Message 1 of 3
Can I turn an individual mobile SIM plan into a family plan
Hi all,
I want to move to BT mobile. I can take a plan now but my wife's contract runs until July. If I take an individual plan now, can I turn it into a family plan when she's off contract?
THanks
2 REPLIES 2
Message 2 of 3
Re: Can I turn an individual mobile SIM plan into a family plan
Yes you can, Family sim plans mean you both get the same allowances each and a discount for having multiple sim plans.
It might however be worth checking your data usage with your wifes, it might work out cheaper to have a plan that suits your needs and a plan for your wife's needs, not a family sim but 2 different sim only plans.
When the time comes speak with the sales team, choose what works best for you 🙂
Message 3 of 3
Great! Thanks a lot for the advice
