alikat
Message 1 of 3
Can I use an existing EE PAYG SIM card for a new BT SIM only deal?
I suspect that the answer to this question will be "no", but I was wondering whether it is possible to use a SIM card which I currently use in an old PAYG mobile for a new Smartphone with a BT SIM only deal, as I am aware that BT uses the EE network.
If not, is there any chance that my existing mobile phone number can be transferred to the BT SIM?
2 REPLIES 2
Message 2 of 3
Re: Can I use an existing EE PAYG SIM card for a new BT SIM only deal?
BT would need to provide you with a new SIM card as these as not transferable between service providers, regardless of any network sharing that takes place.
Yes, you can keep your old number provided that you get a PAC code from your previous supplier. They are obliged to provide one on request.
This is the BT Mobile switching link which explains the process more fully.
alikat
Message 3 of 3
Many thanks for your swift response, Longshanks.
