blwhite74
Message 1 of 3
Can mobile data be transferred to another mobile within family SIM?
Under the current plan all 4 family SIMs have 10gb of data, but 3 of us do not use even half this data. My teenage son runs out after a few days! Is there any way he could have more data and we have less?
2 REPLIES 2
Carlusha
Recognised Expert
Message 2 of 3
Re: Can mobile data be transferred to another mobile within family SIM?
That's not how it works. The allowance is shared amongst all the family. If it is running out, then speak with your lad!
I am, of course, referring to the so-called Family Sim Plan.
-Richie-
Guru
Message 3 of 3
The allowance is not shared between the plan, every sim have their own data allowance and it's not possible to gift or share your allowance.
You might find it better to move your sons mobile from the family sim and have it separate, that way the remaining sims benefit from the saving and your son has the allowance he needs.
