kmcguinness9
Message 1 of 2
Can't change my mobile plan getting an error on MY BT
  When I'm trying to update my plan this message shows up on my package overview page so I cannot do anything this this.
1 REPLY 1
Dean007
Recognised Expert
Message 2 of 2
Re: Can't change my mobile plan getting an error on MY BT
Hi @kmcguinness9
Thanks for posting, If you are unable to change your plan tomorrow it would be worth having a chat with the mobile team. They will be able to look at changing the plan or raising a fault if the system is unable to do so.
