moorview
Message 1 of 4
Can't get a replacement Sim
I bought a new phone, needed a replacement Sim. Ordered one, didn't arrive, ordered another, didn't work !! Called BT the operative ordered another, didn't arrive, same thing happened twice more. Complained, operative said "only one thing to do, get a new number, new sim" reluctantly agreed, guess what, new sim not arrived.
Does anyone know who else I can complain/ sort this out with as just phoning BT has been useless, haven't had a mobile since xmas, any ideas would be welcome, thanks.
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Can't get a replacement Sim
Hi @moorview thanks for posting, I can't believe that this has happened and I'm so sorry that multiple replacement sim's have not arrived or not worked.
We'll be happy to raise this with the BT Mobile team on your behalf. I'll send you a private message in a moment with details on how you can raise this with the modertation team.  https://community.bt.com/t5/notes/privatenotespage
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Moderator
Moderator
Message 3 of 4
Hi @moorview
Sorry you've experienced so many problems replacing your sim. I tried calling today, I can see there is an open complaint with one of our complaints teams and an order showing you have left BT Mobile. Do you still want the complaints team to call you or should we close the case?
Stuart
Community ModeratorStuartH
Kudos”
moorview
Message 4 of 4
well no one from any "team" has contacted me since just after xmas, I am hugely dissappointed with the service from BT. I have decided to leave BT mobile so you might as well close the case, can't say it has has reached a satisfactory conclusion however,
