Ronnie234567
Message 1 of 2
Can't remove add on?
Hi,
I have a 1GB add on attached to my mobile account, I would like to take it off. I go to manage add-ons under my BT but it doesn't seem to have the option.
It keeps pointing me to progress and order and then tells me I already have an add on so cannot add another. I would like to remove it, not add anything.
Thanks.
1 REPLY 1
Dean007
Recognised Expert
Message 2 of 2
Re: Can't remove add on?
Hi @Ronnie234567
I would suggest talking to the mobile chat team who should be able to help and tell you when the change would take effect.
BT Mobile Chat
