NeilO
Moderator
Moderator
Message 11 of 16
Re: Can't speak on phone, how to contact customer services?
Hi @VickiParrott Thanks for getting back to me, I'm sorry to hear your Father is unable to speak after his operation and I hope he makes a good recovery.
I think the Relay UK service would best suit his needs but unfortunately, I can't provide you with technical support to get that up and running.
Have you contacted Relay UK directly to get assistance setting it up? This link will bring you to their contact information page.
Neil
VickiParrott
Message 12 of 16
Thankyou @NeilO I have used that link to send a message with the questions
VickiParrott
Message 13 of 16
I have contacted RelayUK and will let you know if I hear back anything useful!
NeilO
Moderator
Moderator
Message 14 of 16
Thanks for the update @VickiParrott, I'm sure they'll be able to help.
VickiParrott
Message 15 of 16
@stuartrogerson I have had a reply back and it works!! Reply was:
The noise that you are hearing is a normal part of the call connection process.  When you make a call please dial the number from the app, you will then be taken out of the app on onto the phones dialling screen.  When you hear this noise please go back into the app and join the call.
Hope that helps you too
JohnC2
Moderator
Moderator
Message 16 of 16
Hi @VickiParrott  thanks for the update and good news to hear you have got it set up ok now 🙂
cheers
John
