Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
Hi @VickiParrott Thanks for getting back to me, I'm sorry to hear your Father is unable to speak after his operation and I hope he makes a good recovery.
I think the Relay UK service would best suit his needs but unfortunately, I can't provide you with technical support to get that up and running.
Have you contacted Relay UK directly to get assistance setting it up? This link will bring you to their contact information page.
Neil
Thankyou @NeilO I have used that link to send a message with the questions
I have contacted RelayUK and will let you know if I hear back anything useful!
Thanks for the update @VickiParrott, I'm sure they'll be able to help.
@stuartrogerson I have had a reply back and it works!! Reply was:
The noise that you are hearing is a normal part of the call connection process. When you make a call please dial the number from the app, you will then be taken out of the app on onto the phones dialling screen. When you hear this noise please go back into the app and join the call.
Hope that helps you too
Hi @VickiParrott thanks for the update and good news to hear you have got it set up ok now 🙂
cheers
John
