Message 1 of 2
Can't switch mobile plan
I am trying to upgrade the mobile plans I currently have (4), but when I use the online system it fails and I get following message:
As a security precaution we've stopped your online journey as the landline number in your My BT account is different to your actual number. To update it, please take the following steps:
Log in to My BT (https://my.bt.com/s/apps/appspackages/?siteArea=con.mya&s_cid=con_FURL_updateyourprofile)
Click 'Edit' next to your account number or name at the top of the 'My Profile' page
Enter your new phone number in the last field, tick the box to remove the old number and click 'Save'
Once you've done that you should be able to re-start and complete your order
When I follow the link it does not allow the change suggested.
Been at the same address for over 20 years so can't be to do with that. Maybe because we have two landline numbers at the same address?
Has anyone found a solution to this?
1 REPLY 1
Message 2 of 2
Re: Can't switch mobile plan
have you tried phoning CS 150 or 0800800150 from mobile and see if they can help you switch mobile plans
