JosephH1
Message 1 of 5
Cannot find the mobile data settings on iPhone SE
Hi, I recently chage from O2 and since the move, I seems to have lost the ability to either see or change the mobile data settings. Basically the option is totally gone.
Had to change the data setting when I was in France few months ago when I was still on O2 so I know the option was there. Just don’t want to have potential data roaming issues in the future if I ever want to change the settings.
According to the BT help page, you should be able to see or change the setting,  so could anyone help?
BTW I’ve already done a full reset on the phone but the option is still missing.
4 REPLIES 4
Dean007
Recognised Expert
Message 2 of 5
Re: Cannot find the mobile data settings on iPhone SE
Hi @JosephH1
The APN settings for BT mobile are hidden by the network on an iPhone.
You can check the data roaming setting in :
settings - mobile data - mobile data options
and you can see the carrier version in :
Settings- general - about
JosephH1
Message 3 of 5
Thanks for replying.
I suppose the info here is out of date then: http://bt.custhelp.com/app/answers/detail/a_id/52697/c/7168
Dean007
Recognised Expert
Message 4 of 5
@JosephH1
The visibility of the APN settings is network specific. Bt choose to update the APN via the SIM
With iOS 12 the carrier settings is BT-C 33.00
JosephH1
Message 5 of 5
Got it, thanks.
