markeagles4
Message 1 of 4
Cant upgrade sim only account
Im on a 500mb taffif on my sim only plan and would like to upgrade but when i use the online change my plan it wants me to take out a new 12month sim only plan? no option to upgrade my sim as im going over my limit ill have to ditch the BT sim as it will end up costing too much
Regards
Mark
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Cant upgrade sim only account
Hi @markeagles4,
I am sorry to hear about the problems you have had in changing your BT Mobile Plan online. If you contact the BT Mobile Chat Team, they'll be able to help.
Give them a go and let me know how you got on.
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
markeagles4
Message 3 of 4
No they were unable to do an upgrade when ashed the other day , didnt realy get an answer why either, my bill is nearly £50 now so if i cant upgrade plan ill have to use another sim untill december and just ride out the £5 month untill i can cancel
liggerz87
Message 4 of 4
Better to phone and say you want more data
