SFEspo007
Newbie
Message 1 of 3
Cell phone stuck in some training app, can't get out of it...HELP
I was going through some sync type tutorial on my Google Pixel 2 cell, and the tutorial has completely taken over my cell and I can't do anything on it. Any suggestions? I took out the SIM...nothing. Removing the battery is not trivial on a Pixel.
2 REPLIES 2
SFEspo007
Newbie
Message 2 of 3
BT Training app issue
I was going through some training on syncing my cell and the smartwatch and my cell phone is stuck IN the training. I can't do anything. It's a Google Pixel 2 and removing the battery is not trivial. Help.
Moderator
Moderator
Message 3 of 3
Re: Cell phone stuck in some training app, can't get out of it...HELP
@SFEspo007   Are you a British Telecom (BT) Mobile customer?
I found this on google
How do you do a soft reset on the Google pixel?
In most cases, a soft reset won't affect data on the device, unless the battery is very low.
  1. Press and hold the Power button (on the right edge).
  2. Tap Power off. If the device is unresponsive/frozen, press and hold the Power button for approximately 10 seconds or until the device power cycles.
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
