Message 1 of 4
Change registered mobile phone
Is there any way to change the mobile phone registered on BT Mobile? I changed the phone I used since I joined to a newer one and I think having my old phone registered is preventing me from using 4G calling.
3 REPLIES 3
Dean007
Recognised Expert
Message 2 of 4
Re: Change registered mobile phone
Morning @leejgorringe
what phone are you using now?
Message 3 of 4
Hey @Dean007
A Pixel 2.
Dean007
Recognised Expert
Message 4 of 4
Hi @leejgorringe
Thanks for posting back. I’m afraid that Handset isn’t officially supported by BT mobile for Wi-fi or 4G calling.
Some Pixel users have reflashed their firmware to try and get it working with a mixed result.
All BT sims are provisioned for the service, but currently only the S8/S9 and iPhone 5s and above are supported.
You can read more about Wi-fi calling and 4G calling using the link below. If you are trying to improve indoor coverage. You can use a BT signal assist box.
BT Wi-fi calling
