organic
Message 1 of 3
Check BT Signal Assist
Is there a way to check my signal assist is working apart from looking at the phone signal as I only just get 1 bar on phone 2 if lucky?
I cannot seem to find any info on it I have just done a reset still the same.
 My IMEI number is one digit out from what is the BT website to my phone. I don’t know if it has anything to do with it or showing one less for security reason.
 Thanks for any help
2 REPLIES 2
StephanieG
Community Manager - Retired
Message 2 of 3
Re: Check BT Signal Assist
Hi @organic When you're on a call connected through BT Signal Assist, the green light will flash slowly and you'll hear a beep at the start of the call. Is this happening when you're on a call?
Just worth noting, if you get out of the range of the Signal Assist while you’re on a call, your call may drop unless there’s a BT Mobile signal available when this happens.
organic
Message 3 of 3
Thanks for getting back to me. I am off shore now and no way of checking it all I know I get one bar on phone 2 on a good day.
Me back home in about a moth will check it then.
