normanh
Newbie
Message 51 of 58
Re: Constant voicemail icon
Getting a replacement SIM sorted the problem for me too, although BT haven't got the message yet, they also told me:
a) it was an iPhone issue
b) getting a replacement SIM wouldn't solve the problem.
Thanks for the solution!
Norman
mrhodge22
Message 52 of 58
Same issue here!!!!
ickle1999
Message 53 of 58
Same issue here too...
Porterdavejp
Message 54 of 58
SAME ISSUE HERE TOO. I moved from O2 to BT. BT say it is a voicemail left over from O2. The o2 guru says it is a BT problem as the o2 account and phone number has been passed to BT. BT have said they will get back to me. Here's hoping.
Cupcake736
Newbie
Message 55 of 58
Hi,
I've also got the same problem, on a Galaxy Note 4. I've just joined BT and had a voicemail from them, deleted it and turned voicemail off, restarted my phone and I still have the unremoveable notification. How can I get rid of it??
Thanks,
Lisa
Cupcake736
Newbie
Message 56 of 58
Ahh, sorry I hadn't seen all of the other comments on my phone! Sounds like I need a new Sim then, when I've only had this one for 2 days =____= great.
derekdel
Message 57 of 58
Hi,
It used to happen when I was EE network, drove me nuts. They will need to reset your mail box as thats how EE sorted the problem for me a few time. Good luck trying to explain that to a call centre! I had it once on my BT Mobile but it had vanished in a few days
Alan-W
Message 58 of 58
Always good to search the history on a problem and see that a couple of years on I now have the same problem after moving from 02 to BT.
