raymond1234
Message 1 of 2
Criminal application for duplicate mobile sim
Can anyone let me know how someone can apply for a duplicate sim and use it while mine is still active. It seems this is possible and i am trying to prevent it happening to me.
1 REPLY 1
-Richie-
Guru
Message 2 of 2
Re: Criminal application for duplicate mobile sim
It would have to be a replacement sim and the old one would be deactivated to stop this, if you think this is happening ring BT and speak with the BT Mobile support team, any replacement would be sent directly to you and then need activating once arrived.
