Message 1 of 2
Data Only Sims
Quick question, as I currently have Halo 2 would the Data be doubled on the Data Only sims as well ?   https://www.bt.com/mobile/data-sim/
1 REPLY 1
Message 2 of 2
Re: Data Only Sims
Yes,
your data allowance will be doubled. e.g. if you are on the basic 1Gb limit, then it doubles to 2Gb.....But you only need Halo 1 for this doubling.
