Message 1 of 1
Data Roaming in Greece
Hi - I have been in Greece for the week and using my data roaming, my data allowance reset on the 24th. For the days prior to the reset I was not charged for data usage within my allowance, for the days after the reset I have been charged for using 2.32 GB of data, which is also showing as the amount I have used from this month's allowance.
Can anyone suggest why this is? I would ring but for the small sum involved it seems pointless
