Recognised Expert
Message 1 of 3
Data add on does it double up with Halo?
I'm looking at adding additional data onto one of my BT mobile phones, does it double up if I'm a BT Halo customer?
For example if I was to purchase an additional 10GB will it double up to 20GB?
2 REPLIES 2
Newbie
Message 2 of 3
Re: Data add on does it double up with Halo?
I had the same question and having checked Halo T&Cs, quote: "Mobile Data Boost does not apply to any data add-ons that you’ve purchased" - so no....
Expert
Message 3 of 3
@WuzzoUKis correct, the BT Mobile plan allowance is doubled, any addons are not included with the Halo double data.
