judy1
Message 1 of 14
Data connection
A few weeks ago I found I could not use my mobile data!! I have 500.mb/month but when away from home & I switch mobile data on..I get a message saying ' no network '...Can anyone tell me what has happened? I'm not using any of the data allowance I'm paying for & I'm pretty sick of not being able to go online unless I'm in a wifi cafe or at friends (Fon is a dead loss!!)
BT mobile online help said he'd reset it...but it hasn't made any difference. Have I suddenly got something unchecked??
13 REPLIES 13
Zombie
Expert
Message 2 of 14
Re: Data connection
Hi @judy1 very strange you can’t use your data even after you have turned mobile data on through the phone. What phone are you using?
Dean007
Recognised Expert
Message 3 of 14
Re: Data connection
Hi @judy1
if you are using an android phone please can you check the APN settings? Try setting these to EE’s presets if possible and give that a try. If you are using an iPhone, try resetting the network settings (you’ll need to re-enter your Wi-fi passwords).
If neither of these work and you have spoken to the mobile chat team, I can ask a moderator to try and help.
judy1
Message 4 of 14
Re: Data connection
My phone is a Microsoft Lumia 640...and...no longer supported by Microsoft...I'm hoping you're not going to say that is the problem....it was OK to about 3/4 weeks ago!!....And...I love my phone...but very sick at Microsoft!!
Dean007
Recognised Expert
Message 5 of 14
Re: Data connection
Hi @judy1
did you manage to check the APN settings?  For some reason from time to time they get mixed up can sometime block data.
If you can check, try the EE settings
judy1
Message 6 of 14
Re: Data connection
Hi Dean007
On my Settings/ Internet APN everything is blank except Authen.Type PAP...& IP type ..IPv4
When I go into Sim settings - Network says Automatic. Mobile connection profile : BT
Manual Internet APN: Off....Should this be on? When I cli8cked ON, it was all blank for APN/UserName etc
Thanks for your help....much appreciated!!
Dean007
Recognised Expert
Message 7 of 14
Re: Data connection
Hi @judy1 It should look something like this; Name: Internet APN: everywhere Proxy: Not Required Port: Not Required Username: eesecure Password: secure Server: Not Required If you don't have thing like this, click + and create a new profile see if that helps
judy1
Message 8 of 14
Re: Data connection
I must sound a bit thick...but why is it eesecure when I am with BT?
Dean007
Recognised Expert
Message 9 of 14
Re: Data connection
@judy1
BT Mobile is a MVNO (Don't own their own network), they use EE. BT Mobile do have their own settings but it has been known for them to get mixed up in the settings when an update has happened on the phone. The EE APN on some handsets allows wifi calling (not all) but I will include the link for all of  BT's settings, as you will see its almost the same!
BT APN settings for Android
judy1
Message 10 of 14
Re: Data connection
Hi Dean
Thank you...I have changed the settings but I won't know until tomorrow when I am away from the BT wireless hub if it has 'done the trick'...let's hope it works! (Oh ye of little faith...I'm going to take my other mobile with me tomorrow just in case I've lost all my settings, ha, ha!)
