Distinguished Guru
Message 1 of 3
Data roaming in Spain
So, come to spinning holiday expecting data to work on my phone however it's not connecting. Is there anything I should have done or should it just work? I make and receive voice calls.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
2 REPLIES 2
Dean007
Recognised Expert
Message 2 of 3
Re: Data roaming in Spain
Hi @Devon_Dave
Did you check that your data roaming is switched on via bt.com? And that you have an appropriate cap set? if they are both ok, it should work using roam like home.
Make sure the handset network selection is set to auto and if you are using and android that the APN hasn't got mixed up, it should be
  • APN: everywhere
  • Authentication type: PAP
  • User name: eesecure
  • Password: ee
Distinguished Guru
Message 3 of 3
Thanks Dean. Will sit and check settings when the Sun has gone.
