Scuddy
Message 1 of 4
Does Wi-fi calling work when I am in the USA?
Or just in the UK?
3 REPLIES 3
monarchjock
Message 2 of 4
Re: Does Wi-fi calling work when I am in the USA?
Read the pinned posting "Introducing Wi-Fi and 4G Calling on BT Mobile " then follow the link to "Learn about Wi-Fi Calling and how to set it up"
Scuddy
Message 3 of 4
Is that a Yes or a No?
Moderator
Moderator
Message 4 of 4
@Scuddy No, Wi-Fi Calling doesn't work while you're roaming.
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
