slogger
Message 1 of 2
Don Webster - A shining star of customer service in a mire of mediocrity
I won't go in the details of 6 weeks of hell with BT customer service in trying to transfer mobiles from one account to another and being told it was completely impossible but today I was fortunate enough to be put through to Don Webster (Cardiff or Swansea, I was so amazed I forgot which).
A man who is polite, personable and actually very good at his job. When I told him my problem he said it was simply a case of asset migration, a bit tricky but he would do his best.  When I told him that everryone else at BT had said it was impossible he replied that it was "only impossible if i can't do it".
Ten minutes later the job was done. Thanks Don you really are a star.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Don Webster - A shining star of customer service in a mire of mediocrity
Hi @slogger,
Thank you for taking the time to post. Its always great to see some positive feedback, I've pass on your comments to Don's manager.
Cheers
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
