Message 1 of 4
Due a Upgrade...
I'm due an upgrade so I go to check the Phones on offer and there's only 4!!?
What's going on, no mention of the new Galaxy s22 or the recent version(s) of iPhone?
3 REPLIES 3
Message 2 of 4
Re: Due a Upgrade...
BT offer budget phones and sim only now, the premium range are now supplied and supported via EE, if you're a BT broadband customer and you go via www.bt.com/mybt it will give you 10% off the EE range, you can also call the mobile retention team on 0800 800 150 and they can access the EE systems to find the right deal for you.
If you do go this way, you will have a new direct debit with EE along with your normal BT direct debit for any other services.
Message 3 of 4
Thanks for the information! 😊
Message 4 of 4
It’s not quite as straightforward as just getting a new phone from EE you’ll be credit checked again and set up a new EE account which you’ll have to port your number over to.
