jgwors
Message 1 of 9
Enable calling from outside UK
I've gone abroad under the assumption that my mobile contract allowed calling from outside the UK. Well it doesn't. And the catch 22 is that I can't call the help desk to sort it out?
What other ways are there of calling the help desk?
8 REPLIES 8
garybs29
Message 2 of 9
Re: Enable calling from outside UK
As you're able to get online, I can suggest logging into my BT & checking your spend cap as that may be causing the issue & an increase in it may resolve it
albertj
Message 3 of 9
Where are you travelling?
You can use your BT Mobile in these countries for free:
Roaming Countries included
Zone 1aAustria, Belgium, Bulgaria, Croatia, Cyprus, Czech Republic, Denmark, Estonia, Finland, France, Germany, Greece, Hungary, Ireland, Isle of Man, Italy, Latvia, Lithuania, Luxembourg, Malta, Monaco, Netherlands, Poland, Portugal (including Azores and Madeira), Romania, Slovakia, Slovenia, Spain, Sweden, Vatican City
Zone 1bCanary Islands, French Guiana, Gibraltar, Guadeloupe, Guernsey, Iceland, Liechtenstein, Martinique, Mayotte, Norway, Reunion, Saint Barthelemy, Saint Martin, San Marino, Switzerland
Source: https://bt.custhelp.com/app/answers/detail/a_id/50074/~/how-do-i-check-the-costs-of-using-bt-mobile-...
The zones just mean different charges if you use up all your allowances.
If you're outside of the EU, you can check the costs here: https://www.bt.com/mobile/calling-charges/ I think by default they cap it at £35, which you can increase here: www.bt.com/mymobile
Other than finding a phone to use, or using your own; I can't think of any apps other than 'FreedomPop' to make UK calls over WiFi, and this app is clunky to use. You could try a live chat, and tell them to call you.
Please press the thumbs up if you found my response useful and mark it as a solution if I resolved your query.
jgwors
Message 4 of 9
Thanks for the reply. I'm in Denmark so expected to be able to use the phone as if in the UK
albertj
Message 5 of 9
Yes, you should be able to.
Does calling, texting and data not work, or only a few?
You could also try following the steps for your device:
How to set up an Android phone >
How to set up an Apple iPhone >
How to set up a Windows Phone >
jgwors
Message 6 of 9
Data is OK. No problems there. Don't really use text - mainly whatsapp. Can't even call over wifi
jgwors
Message 7 of 9
Texting is OK. Just calls that don't work
albertj
Message 8 of 9
Most modern phones will do this automatically, but you are dialling over +44?
You could try manually selecting a network in Denmark and see if that works. I don't know who's BT's roaming partners over there so if there are any other networks you can connect to, I don't know which would work.
jgwors
Message 9 of 9
Thanks for your suggestions. I tried other networks without success. Seems I will have to sort this out when I'm back (for next time)
