Message 1 of 17
Family Sim Moving to EE
BT are moving our family sim to EE.
I've received 3 new sims but only been given one PAC code.
How do EE know which phone to transfer which number to?
Sorry if that's a silly question, I only like technology when it works without any input from me!!
16 REPLIES 16
Message 2 of 17
Re: Family Sim Moving to EE
Hi, @JoJo56 Welcome to the community and thanks for posting.
You'll need a PAC code for each number. The easiest way to get a PAC code is by texting ‘PAC’ to 65075 from your BT mobile sims then contact EE with the corresponding PAC code.
Neil
Message 3 of 17
Thanks Neil, that's what I thought but when I rang BT they said one was fine and put me through to EE, but as my husband wasn't home and he pays the bill I couldn't get past their security clearance to get a coherent answer!
Will try your suggestion
Jo
Message 4 of 17
If the sims are linked a sin a family sim they are there is usually only 1 pac for all 3 numbers. If not already given EE should take it to transfer all 3 numbers without any issues
Message 5 of 17
Thanks Gary - it is on a family sim deal but how will EE know which number to transfer to which new SIM - I don't want my daughter's number to be put across to my husband's phone for example, that could end very badly!!
Message 6 of 17
If they haven't been done yet they'll be able to know which sim has the number provided by them with the sim numbers & be able to process them accordingly so you shouldn't have to worry about that
Message 7 of 17
Thanks Gary - fingers crossed!
Anonymous
Not applicable
Message 8 of 17
Did they issue you with a PAC for each line and have you provided that to EE?
The process isn’t automatic and one PAC won’t initiate a number port for multiple numbers. That’s not how the system works, each PAC is unique.
@NeilO are you able to confirm please?
Anonymous
Not applicable
Message 9 of 17
I only got one PAC code when moving 4 Family SIMs away to another provider 18 months ago, so this has been the case for a while. I got 4 temporary numbers  from the new provider, then had to match the temporary numbers to the desired numbers online.
It worked OK, but I agree a PAC code per SIM would be much easier as it required more work from me (creating an online account, matching numbers to SIMs). I'm quite techie, I should imagine it would be a real faff for someone who wasn't.
That said, as BT own EE, this should work seamlessly, shouldn't it?
Message 10 of 17
Seamlessly would be wonderful but then there's reality 🤣
Thanks for the insight in to how you achieved it. Will give it a go over the weekend when the more techie than me kids are at home.!
