Message 11 of 20
Re: Fastest 4G speeds with Plus
Thanks for the chat link. I was confirmed I have 40GB allowance but will only ever see 20GB listed, until it runs out. I’ll then see the extra additional 20GB. Little bizarre.
Would like to get some feedback from other Plus users who use all of their allowance up and get the ‘rescue’ data offered
Recognised Expert
Message 12 of 20
Hi @nikiandemma
That’s not correct. lf you download the btmobile app you see the additional data straight away. So if you have a 20gb plan as I do it shows 40Gb
Message 13 of 20
Sadly I cannot paste a screenshot on here but the BT Mobile app acknowledges I’m a Plus customer but is still showing the 20GB still. I’ve reset the app etc to no avail. I just contacted online chat and they said that my Plus order did not contain mobile. I really don’t know why they are so incompetent to look at my order history and piece together the same story I’m telling them, for themselves to review and discover somethings wrong. I’ve no option left now but to call tomorrow morning. Not a great start.
Recognised Expert
Message 14 of 20
Hi @nikiandemma
as you have tried to resolve this with no luck. Let’s ask a moderator to assist you in the morning. They will post a link and invite you to send them your details. They should be able to help.
Please check back on Saturday for their message Smiley Happy
Moderator
Moderator
Message 15 of 20
Hi @nikiandemma
Thanks for your post and welcome back!
Sorry that you're not seeing your extra data after signing up for BT Plus.  Send us your details over and we'll check what happened.
Click on my username here >> RobbieMac << and you'll see our contact link underneath my profile picture.
Cheers,
Robbie
Message 16 of 20
Hi Dean, Thanks - all sorted now, I called the 150 team earlier and it's because I did my number port just minutes before the Plus upgrade, consequently my original BT SIM number was removed and not included as part of the transfer across. So I guess a note to others, do not port until you have Plus all up and running. Thanks for your responses throughout - much appreciated. Nick
Message 17 of 20
Thanks Robbie for getting in contact. See above response, all sorted now after a call to 150.
Recognised Expert
Message 18 of 20
Hi @nikiandemma
I’m glad they finally sorted it, and it’s one less thing for @RobbieMac to sort out.
If you are happy with outcome, please mark as solved 😀
Moderator
Moderator
Message 19 of 20
Excellent stuff @nikiandemma
Great to see you got it sorted.
Cheers,
Robbie
P.S I have marked your post as the solution Smiley Happy
Message 20 of 20
