nikiandemma
Message 1 of 20
Fastest 4G speeds with Plus
Hello,
Does this mean the same as EE provide, say 90Mbps + or do these speeds top out at 60Mbps? Are you essentially getting a free upgrade to BT's 'Extra Speed' or is totally unthrottled?
I've literally only had BT Mobile for 2 weeks (20GB with Extra Speed incl.) and now if I signed up to Plus, would I get 40GB and 4G+ speeds?
19 REPLIES 19
Dean007
Recognised Expert
Message 2 of 20
Re: Fastest 4G speeds with Plus
Hi @nikiandemma
it’s the fastest speeds available to BT on that mast and a max of 60Mbps
orozz
Message 3 of 20
Extra speed plan can exceed 60Mbps, just now in central Birmingham 1C3190C2-399F-4B36-A74C-EDAD203E056E.png
Dean007
Recognised Expert
Message 4 of 20
Hi @orozz
Now you are showing off and I’m jealous Smiley Happy
clearly that have really increased it to the maximum speed that BT can give on a local mast can, although clearly speeds will differ from mast to mast.
BT can still surprise me, and not always in a bad way lol
clever_trevor
Message 5 of 20
Hi - I just upgraded & seeing 68Mbps in my area - am very impressed by the extra speed
Dean007
Recognised Expert
Message 6 of 20
Thanks to this post I’ve spotted issues on my sim/accounts. And it seems my sims are locked at 60 even in 4G+ areas
benfish
Message 7 of 20
Just upgraded to BT With Plus and mines always been capped at 60mbps.  Well now it's not!
Dean007
Recognised Expert
Message 8 of 20
@benfish
With Plus you will get the fasted speed of 4G BT Mobile has access to on that transmitter, in some places where they have 4G+ and slots you will go above 60.
However you can always check with the mobile chat team that Plus additon has been applied to your account correctly.
nikiandemma
Message 9 of 20
Awesome! Can I ask if you had the double data applied to your account too? I’ve upgraded to Plus yesteday and although it now says I have it, my 20GB is still showing. My number ports across tomorrow so I guess they’ll let the account settle first.
Dean007
Recognised Expert
Message 10 of 20
Hi @nikiandemma
one your upgrade to plus completes you should get an email. Both the mobile app and at BT.com should say on your account that your a plus customer.
BT’s system only normally allows one order at a time so with the port it may not happen until after. If for some reason it hasn’t please contact the mobile chat team who can look into it further
BT Mobile Online chat
