S4Brains
Message 1 of 5
Getting back of Galaxy S6
So, organised the family sim package and need to put the new sim in but can't get the back off the Galaxy S6.  I don't use the name S4Brains for nothing.  How do I get the back off please?
4 REPLIES 4
Distinguished Expert
Message 2 of 5
Re: Getting back of Galaxy S6
Apparently there's a downloadable manual, or if you are really smart, there's even a you tube video.
You need a large suction pad and two guitar plectrums.
All readily available items Smiley Tongue
Steel fingernails or a Swiss knife may be too much, though.
Maybe a watch maker / repairer, could help.
Moderator
Moderator
Message 3 of 5
@S4Brains You don't take the back off the S6 to insert the sim, there's a slot that you have to eject using a pin that pops out the sim card from the side of your phone.  The Samsung support site shows you how to do this.
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
S4Brains
Message 4 of 5
Thanks peeps.   Doh!
Moderator
Moderator
Message 5 of 5
No problem Smiley LOL
Kudos”
